11-10-2022 10:11 PM
Hi, I'd like to know what to do in order to receive and make call from outside UK. Thank you.
11-10-2022 10:50 PM
@Baye : Where are you? In Senegal or in UK calling the Senegal?
12-10-2022 11:29 AM
12-10-2022 11:33 AM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
12-10-2022 11:44 AM
12-10-2022 11:56 AM
First of all, your pack is useless there; they are only for use in UK & EU.
As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/help-new/roaming-costs/countries/senegal > PAYG.
More immediate, your PAYG SIM has gone into hibernation after so long non-use.
EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
12-10-2022 12:13 PM
12-10-2022 12:20 PM
No, it's too late! It's over 6 months. So you need to call CS to reactivate it.
12-10-2022 12:26 PM
12-10-2022 12:35 PM
Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
