on 20-07-2023 06:52 PM
Solved! Go to Solution.
on 20-07-2023 07:23 PM
CS can reset your voicemail PIN if you contact them on 150.
on 13-12-2023 09:06 AM
Impossible to conect to a person to recive a pin get shut off then recuve a text to conact them
on 13-12-2023 10:35 AM
Hi @On2
Thanks for posting.
If you call us on 150 and select technical support and hold for an agent one of the team will be happy to help 🙂
