on 27-03-2024 03:14 AM
on 27-03-2024 04:17 AM
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 27-03-2024 04:41 AM
on 27-03-2024 07:34 AM
Hi @Scottymatt
Please try calling us after 8am UK time and the team will get the account looked into to get this sorted for you.
on 27-03-2024 08:48 AM
he hasn't got a working phone!!!
how can we call you??
on 27-03-2024 08:52 AM
I am in KSA and cannot phone the UK using my phone. I have tried everything. I do not know what more I can do.
Should it really be this difficult in 2024 for a bill-paying adult to make the conscious decision to make phone calls that they will pay for?
Seems a change of provider for my families four accounts I pay is on the way.
on 27-03-2024 09:53 AM
Thanks for coming here.
The call would need to be from any other phone or third party calling app such as Skype advised by @XRaySpeX.
Did you text ROAMING to 150 to check roaming was set up on your account before travelling?
Have you tried manually searching for an available network?
Leanne 🙂
