Issue with activating Roaming
stuf83
Both myself and my partner have the same issue so wondering if this is a known issue at the moment as wait times to get through to CS are stating 30mins+?
I've always had roaming and international calls allowed on my account and the other day I noticed both state blocked now. I've tried to activate on the website and My EE App and it tells me there is an issue and to text info to 150 to make the changes. However, when text roaming to 150 it states I have EU roaming only and international calls are blocked. If i text "Roaming full" it states it has changed it but nothing changes on the app or website and also if i then text "roaming" to 150 again it states I only have EU roaming so something isn't right. Given my partner has the same, can anyone confirm if they face this issue and if its being worked on before i spend all that time waiting to get through to be told the same?
7 REPLIES 7
Leanne_T
Hi there @stuf83
This would need investigated for you by our mobile care team, please call us on 150 and the team can open a support ticket for your My EE showing roaming blocked.
@Leanne_T , many customers have this problem, I have this, but my account when I rang them before going abroad, was told it was enabled. I believe this started last year, and does not seem to be rectified, for some reason, I think this does need looking into, fortunately not all customers have this, but many do, have always had roaming, 27 years now, since I joined, when it was Orange!!!
Leanne_T
Thanks @Schockwave
If you can give us a call the team can raise a support ticket for you, this would be looked into by the relevant team.
Thank you @Leanne_T , I raised this when I went on holiday and it still has not changed, not a problem at present, have just changed to a sim only contract, and when I go abroad will speak to them then, as it worked ok when on holiday. Strange, as this is only happened when others mentioned it and I took a look, as you do at your settings on occasions.
stuf83
Hi @Leanne_T
I called CS and its a known issue that is being worked on but was a long wait to get through. Surely there should be some sort of update posted on here as this is driving calls in when its a known issue?
Anyways, no timescales to fix at present which is disappointing but least its being worked on.
Leanne_T
Thanks for coming back and letting us know @stuf83
The team would be able to check your account and run through some troubleshooting to add your details to a support ticket, if this was required.
