30-06-2022 01:15 PM
Now I am using UK network EE sim
now I am in india I need to get OTP from bank to my uk EE sim but I don’t have international roaming
now what should I do?
30-06-2022 01:17 PM
@Rajasekhar : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
30-06-2022 02:12 PM
I am in india now
I have add new plan for international roaming
but not showing signals
i didn’t get any message and calls
30-06-2022 02:40 PM
Hi @Rajasekhar
Thanks for posting.
Have you been able to try the steps @XRaySpeX has posted above?
Thanks.
