International phone/data useage
Lou441
Under controls on my phone I am not able to active international calls/data
In Switzerland recently I was unable to use data/connect to WiFi. Despite calling 150 there was no solution provided and am informed “it's all set up”
I moved to EE due to coverage where I live in UK but i need to be able to use my phone ANYWHERE in the world. So far very unimpressed with EE.
Northerner
Hi @Lou441
You'll need to speak to EE as you might need to pay a deposit for using EE roaming benefit.
https://ee.co.uk/contact-ee/contacting-abroad/mobile
I did speak to EE - for over 30 mins when I was stuck at Zurich airport with no means of contacting anyone. The response being I had international roaming…🤷‍♀️
Thanks for your reply
@Lou441 : If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. over Skype. It should be free.
