30-08-2022 03:08 PM
I am in the US. Everything is on but can’t get calls or texts. What’s happening?
30-08-2022 04:14 PM - edited 30-08-2022 04:15 PM
Hi @evieg
Thanks for coming here.
Do you have roaming activated in your My EE account online?
Have you restarted your phone?
30-08-2022 04:31 PM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
