In Italy and my roaming data and call doesn’t work
HashemAbdi
I just got my line yesterday and I have looked online and I can’t find a solution to my problem. I paid for the full EU roaming plan and it says it is active on my line but it doesn’t work. It says to select network but I don’t even get that option and I can’t call ee customer support since my phone doesn’t work
Jon_K
Former EE Employee
Hi @HashemAbdi.
Are you trying to manually change network while you're abroad?
This may take a few minutes to search in settings.
What phone are you using?
Did you use the phone in the UK before you went abroad?
Jon
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
