on 09-08-2024 10:17 AM
Hi
how do I get my phone to work having followed all EE instructions. I’m abroad and can’t call. The website has also been useless in helping to find other ways of contacting EE.
Solved! Go to Solution.
on 09-08-2024 10:59 AM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app such as Skype over WiFi..
on 09-08-2024 10:41 AM
Hello @bisi3 ,
Welcome to the community,
Where are you abroad?
Are you on pay as you go or monthly contract? If on monthly contract, did you enable roaming on your account? If on pay as you go, this is automatically enabled.
Did you receive the welcome message. Sometimes just rebooting your phone will work.
You will have to ring customer service to enable roaming if on monthly contract, you can’t act customer service if you have something like Skype for free, see my signature.
on 09-08-2024 09:14 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
