25-12-2022 12:38 PM
I need to receive and make calls and send and receive sms in the USA for PAYG. I dont use data. I only use phone calls and sms. What did I need to do
25-12-2022 02:04 PM
Just top-up lots before you go. PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously.
As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/help-new/roaming-costs/countries/usa > PAYG.
25-12-2022 02:04 PM
26-12-2022 08:21 AM
Never needed. It is a phone.
I need to receive and make calls and send and receive sms when I am in the USA for PAYG. I dont use data. I only use phone calls and sms. What did I need to do.
2 months ago I was in the US for 3 weeks and my phone did not work at all!! Nothing, zero.
It is a samsung and works when roaming in EU, Australia, Japan etc .... why not the USA
26-12-2022 08:33 AM
Hi @PeterUSA1
Did you try manually selecting another network?
If the SIM is active and you have credit, this should work for you when roaming.
