on 10-11-2022 12:32 AM
I’m trying to go to myEE but it’s down for updates or upgrades! Not sure how to contact CS from Germany. I have WiFi but would like to have roaming on my phone. Is it just outbound calls that are charged and he does the charge work for calls I receive?
on 10-11-2022 12:40 AM
@Yoo13 : All calls, in or out, trigger the £2 / day surcharge if you are on contract.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
