EE roaming in the US
Copsonc
Hi - I've paid £10 monthly to have connection in USA - it's been a disaster - no 4/5g unless I turn airplane mode on and off - then it lasts 2mns- no phone service . Really fed up- any suggestions? Thanks
6 REPLIES 6
@Copsonc : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Hi
Yes I’m on contract.  Texted 150 roaming before i left uk and paid £10 . When I go into settings cannot activate roaming which is off - telling me to text 150 but I can’t because I cannot connect to ANY network manually or automatic . Turned device off and on yesterday- furious!
Hi @Copsonc
If you cannot activate roaming then you need to speak to EE CS and probably pay a roaming deposit.
You can use live chat to contact EE or Skype using the number in @XRaySpeX post above.
The £10 charge you refer to is for the Roam Abroad pass which enables you to access your UK allowances for usage in the USA.
It is quite separate from the roaming facility which enables your phone to connect to local networks in foreign countries - this is free of charge.
Ok sooooo why can I not connect to any local phone network nor keep 4G for more than 1 minute ?
I guess I will have to try and call some 0800 number for CS tomorrow
Do you have a Google Pixel 6 by any chance?
