How to iPhone a mobile in uk fro mobile in turkey
Ritnotpetite
How do I call a. Mobile in the uk from my mobile. I am in turkey at the moment
If your phone has a connection to a Turkish network, then simply dial the number as you would normally.
You may need to redial the number in +44 format, but it should often connect as normal without needing this.
