Help turning voicemail off
RoxA
Hi there!
I have looked through at least a dozen threads on this topic, but the common reply of texting VM OFF to 150 does not work for me. I have also tried texting VM ON and then VM OFF, still no luck. I am met with the reply of 'Sorry, we're having some trouble completing your request at the moment. Please try again later.'
I have been trying this on and off for a few months and it is always the same reply.
I am pay as you go, if it is relevant.
Does anyone have any suggestions for me, please?
Thank you and have a lovely day!
44 REPLIES 44
Katie_J
That's great to hear @Ladybird97
Thanks for letting us know.
Katie
Brilliant, worked well, thanks...
Leanne_T
Thanks for letting us know @tinaparkes078
Leanne 🙂
That worked for me.
Now how do I undo it now I want to re-enable voicemail?
Thanks Martin
Peter_W
Hey @martinonorcas 😁
Welcome to the Community!
Have you tried the standard VM ON to 150 for re-enabling your divert?
The GSM code works for disabling all diverts on the handset, you should be able to request diverts again via this method.
Peter
Thank you.
Great advice.
Looks like simply re-enabling VM worked fine.
Martin
Debbie_G
Thanks so much for coming back and letting us know @martinonorcas
It's great to hear this has worked! Have a great day.
Debbie 🙂
I assume this isn’t possible from abroad whilst not on a roaming package?
_MrR_
Scholarly Contributor
So if you’re abroad and you’re connected to a network, then the best advice is the GSM code route.
As in dial: ##002# in your phone and then dial it like a phone number.
That’ll cancel the diverts from your line and therefore switch off the voicemail.
Thanks I’ll give it a go 👍🏼
