Help please - in Thailand
russ1311
Hey all so I just landed in Thailand. Forgot to do roaming on my phone or package.
some important work texts have been sent but I’m unable to get any signal with my EE sim card.
any advice? Thanks.
@russ1311 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
russ1311
Hey thanks for your help. I’m on contract and no I forgot to text roaming before my flight.
I’ve tried to activate roaming my self with no joy. I’ll try see if I can call c.s over wifi didn’t think of that. Thank you.
