on 23-04-2023 09:29 AM
Hi, I am in Malta and my iphone 14 has connected to the go mobile network out here. I have network selection to automatic but am unable to make any calls. All I get is a recorded message saying this number is restricted from this network. EE are charging me £2.29 a day and I cant even use it. My wife is on o2 (Giffgaff) and can call me no problem.
on 23-04-2023 09:42 AM
on 23-04-2023 09:51 AM
That's a strange one - you're connected and receiving incoming calls which means the service is working.
Are the numbers you're trying to dial in the international format (e.g. +44 20 78xx xxxx or +44 7788 xxxxxx) as if not, the error message could come from the fact you're trying to dial in a way the network doesn't recognise.
If that's not the fix, I'd so a manual network search and try and hook onto another network there, see if that resolves it.
Good luck.
on 23-04-2023 10:10 AM
Thank you but it didnt work. I will try to get EE to refund my £2.29 a day as I cannot use their service.
on 23-04-2023 10:39 AM
on 23-04-2023 12:05 PM
Hi. i cannot send texts but can recieve incoming calls.
on 23-04-2023 12:19 PM
Thanks @Hobbayne
It sounds like the calling abroad restriction is active on your account, to check this and help get roaming fully set up please call us on +44 7953966250 from any other phone.
on 23-04-2023 01:53 PM
To add, the roaming facility itself is free of charge. The daily charge referred to, is a cost to use your UK allowances within the EU - this is only incurred on any day you use your phone.
