Hello no call and mesage eu
West31
I have problem travel to Germany I'm not cal and mesage
@West31  Are you on contract or PAYG ? If your a contract customer did you enable roaming from within your online account?      If you’re on PAYG did you use that EE SIM card within the uk to make a call/text before you left the UK ? If you didn’t then unfortunately it’ll not work abroad until you do use it within the UK
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
