on 01-04-2022 11:22 AM
I called EE support to understand what my deal is on roaming before boarding a flight to Antigua. I was told I am eligible for Full Roaming (EU+Rest of the World) and that I would receive a text message to say the free add on was being activated. I duly received a text, got to Antigua and have not been able use this facility at all since I got here. Pretty upset. Can someone help?
on 01-04-2022 11:41 AM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu > Account Settings > Parental and Data Controls > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. over Skype. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
