on 01-04-2022 12:26 AM
i will
be travelling to India and wanted to know the charges please .
thanks
Solved! Go to Solution.
on 01-04-2022 01:01 AM
As it is not in EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/help-new/roaming-costs/countries/india .
If you are on contract, remember to text ROAMING to 150 before you leave UK to check roaming is enabled on your account.
