Ee wifi hotspot
Uksmiler1
Are the ee wifi hotspots now live as it doesn't let me set this up but it shows its active on the my ee app
11 REPLIES 11
@Uksmiler1 : What EE WiFi hotspots? Do you mean on the Tube?
That seems to be only for PAYG users.
It's not it's on the new plans that have just been released and is showing on my ee app
hotspots across the UK and London Underground wi-fi access in enabled stations. Subject to device compatibility. Seamless connection for iOS handsets when in range of a hotspot.  To connect on an Android device, manual sign-in required when in an EE retail store or in range of a London Underground hotspot or by configuring settings manually. After initial connection, subsequent connection will be seamless. BT Wi-Fi hotspots subject to change.  London Underground wi-fi access available in ticket halls, escalators, platforms and when the train is in the station. No coverage in the tunnels. Active EE mobile customers only. You are an active pay as you go customer if your pay as you go account has been topped up with a minimum of £5 within the last 30 days. If your last top up took place more than 30 days ago, it can take up to two days from the date of your latest top up to update your account and provide you with access to the service.  Compatible device required. See www.ee.co.uk/wificoverageboost for more information.  Fair usage policies apply.
From the article you quote:
Pay monthly customers:
If you're an EE pay monthly customer with a WiFi-enabled device, you can get WiFi on the London Underground, unless your account is in arrears or has been classified as a bad debt.
c.f.
Pay as you go customers:
If you're an EE pay as you go customer with a WiFi-enabled device, you can get WiFi on the London Underground and in 150,000 locations across the UK if you've topped up your account with at least £5 within the last 30 days.
