Ee hub
Lindatired
Hello, i am not tech savvy and i also have a meningioma growing in my brain so may sound daft
How do i get simcard out of new hub
Linda
@Lindatired : Depends! Remove the battery cover, press a pin in a hole, revolve the little slot cover ........?
You tell us which mobile router & we may be able to tell you.
Leanne_T
Hi there @Lindatired
Thank you for coming back to the community.
We will certainly do our best to help you remove the SIM card. Can you try the advice from @XRaySpeX and let us know if this works for you?
If you need any further help, please share the mobile broadband device you are using?
Thanks 🙂
