on 08-07-2024 08:25 AM
I’m travelling to Vietnam later this month. I have a contract, unlimited data. Will my phone work in Vietnam? Will the roaming pass work?
Advice greatly appreciated!
Solved! Go to Solution.
on 08-07-2024 08:30 AM
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
The Roaming Pass is not valid in Vietnam, the charges are set out at https://ee.co.uk/help/help-new/roaming-costs
