Dialling when abroad
markthornton11
In Corfu and no matter what dial cod I try I can’t connect. I can dial other mobiles and Uk numbers. Even hotel staff are stumped. Any ideas ( I have roaming on)
8 REPLIES 8
Christopher_G
Hi and welcome to the community, @markthornton11
What kind of phone are you using? Are you trying to call a Greek number?
markthornton11
I’m using an IPhone and trying to call the hotel. No version of the dial codes seems to work
It’s Corfu so int code +30
Christopher_G
Could you try toggling the 'Dial Assist' in your settings please, @markthornton11? Just to see if it then works?
Tap Settings > Phone > Dial Assist.
Hi yes I’ve tried with dial assist on and off same result
Christopher_G
OK, thanks @markthornton11
What about manually connecting to a different available network?
Just tried 2 other networks. Same issue. Also disabled Wi-Fi calling
Christopher_G
I'm not sure what is causing the problem, @markthornton11. It seems like you've tried everything we would recommend.
It may be worth speaking to our technical support team so we can check everything from our side.
