Deleting old voicemail messages 2023
ShazzaA
I used to dial my voicemail, listen to my messages and then press 3 to delete....now I don't have that option!  How do I delete them?
Katie_J
Hi @ShazzaA
If you select option two and once you have listened to the message you will be able to select option 3 to delete the message.
I hope this helps,
Katie
Katie_J
Good morning @ShazzaA
Welcome to the community.
What phone are you using?
I have just called my voicemail using an iPhone and I have got option 3 to delete the voicemail after listening.
Katie
The menu option 3 to delete messages is also present when calling from my Android phone.
Katie_J
Thanks for checking @bristolian, that's a great help.
@ShazzaA are you able to check this again to see if the option has came back?
Katie 🙂
Hi I used to be able to do it but for some reason the automated message
just gives me the option to record my own personal greeting (option 1) or
listen to my messages(option 2)....When I try to press 3 to delete my
messages it just starts the whole thing again! I'm using Samsung (android)
Sharon Allchorne
Katie_J
Hi @ShazzaA
I hope this helps,
Katie
