Data roaming
fergusgrey1
I have just arrived to Germany and I forgot to text 150 (EE) “ROAMING”. Now I am in Germany without any data and I cannot send EE a message as you can’t use WI-FI to send a text message. I need data roaming but cannot enable it as I can’t send them a text. Please help
Christopher_G
Hi and welcome to the community, @fergusgrey1
Are you on contract or pay as you go? Are you able to connect to a Germany network operator?
