My roaming is free with contract but will not work whilst I’m away
Buckley77
I have roaming all round included in my package
I have just arrived in the USA my phone will not work I have had to buy an extra day pass just to be able to use my Apple Pay and get my holiday details up for
150 are currently shut to call can someone help me asap
Alex_H
Hi @Buckley77,
Welcome to the EE Community
Do you know which plan it is you have? If you believe roaming in the USA should be included but has not been it sounds like you could have a plan which has roaming available as an inclusive extra but you may not have it selected currently.
If you login to the app select Manage, then Mobile Add-ons, do you have an Inclusive extras section here and if so do you have a roaming pass selected?
Alex
