Data roaming additional charge paid butcant use
Sara1803
Ive paid an additional charge for to use data roaming on the other phone in my contract but says on the other phone emergency calls only and cant use wifi etc ,
@Sara1803 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
