Data and service wont work
Arturas7
Hello , im for while travel in Eu and my EE data service dont work
@Arturas7 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything.
Jong03
Hello im here in Belgium my data wont work. Hopefully
James_B
EE Community Manager
Hi @Jong03,
Are you using a pay as you go or pay monthly plan?
Hi James_B, Im using Pay as you go. I cant make message and calll also in 150. I alredy have subscription for data packs
James_B
Have you purchased a roaming add-on @Jong03?
