Can't send text message - Error 0
BlueFish
I've been using Messages and sending and receiving texts fine, until today. Now when I try to send one I get the error message: Can't send message with EE - error 0.
I can't change the SMSC as that option is greyed out on my phone.
Is there another way I can change the SMSC, please?
65 REPLIES 65
Leanne_T
Hi @Elizabeth2408
Thanks for coming here.
Which phone are you using?
Does this affect all texts that you try and send?
@Elizabeth2408 : What number?
Cant send message and no data but my network was 4g still no data coming to my phone
Euna614840_
Cant send any message even i restarted how many times . Got a good signal with 4 bar still nothing change .plss help i just bought new ee sim i dont know why not working..
Leanne_T
Hi @Euna614840_
Are you in the UK or roaming?
Can you make calls?
JoI79
I'm having the same issue today, for the 1st time
 Please can you tell me how to resolve it
I had this exact same problem ,
I found by changing the messenger app and set new app as default cured the problem.
Let me know if this works
Which app? I use the shortcut on the bottom of the screen. It's not all.messages, just to a new contact I've added today
I'm.able to text myself, my dad and my partner no issues.
Thanks for your help.
@JoI79 : Where are you?
Not sure will help in your case, however I just had one person I couldn't text and got the Error 0 code. I solved the issue by deleting the person out of contacts and re-added them back in. Unbelievably it worked for me, however I have no idea why!
