07-04-2023 10:04 AM
Hello,
I’m unable to receive texts or calls abroad despite I topped up some pounds! In the beginning of my journey I was able to receive texts normally. But after some months I couldn’t receive anything!
I changed my “Network Selection” from Automatic to Manual, and chose other operators but it shows No Service! So I need to switch “Network Selection” to Automatic to get service, but without receiving anything. I also tried to restart the mobile and change the SIM CARD, but it didn’t help at all.
By the way I forgot to activate/add or text my add-on “CALL ABROAD” to 150
I have Pay as you go SIM CARD.
Any possible solutions?
08-04-2023 03:02 PM
I called EE via Skype and it was free 🙂
I talked to the CS and they activated the number. I even texted my EU number and it worked perfectly 🙂
I have just a tiny issue, which is when I log in for example in HMRC’s app, they send me a code to my phone number which I haven’t received in 30 minutes or more. Still reactivate issue or something else?
08-04-2023 03:13 PM
I'm glad you were able to speak to someone to get activated, @Vollys.
Could you try manually connecting to a different available network to see if the messages then come through?
08-04-2023 03:24 PM
Hello Chris,
I turned off automatic Network Selection off, and chose manually. I tried two other available networks, but it shows No Service.
08-04-2023 03:28 PM - edited 08-04-2023 03:29 PM
I'm not sure why those messages aren't coming through, @Vollys
If you're able to, I'd recommend speaking to the technical support team again through Skype. Hopefully they can figure it out.
09-04-2023 10:52 AM
They said it’s normal it takes that long time!
