09-04-2023 08:15 AM
I am in Vietnam at the moment and wanted to know if 120 mins from anywhere covered calls made and received from UK numbers whilst in Vietnam. Thanks
09-04-2023 11:07 AM
@JulieThompson Have a look at THIS I think your looking at the add on that allows you to call anywhere from the UK.
09-04-2023 01:10 PM
To add, be sure to differentiate between incoming calls & outgoing calls whilst you are roaming.
The "calls from anywhere" bundles will cover outgoing calls, but not incoming calls.
