Can’t connect to mobile network in Portugal despite buying roaming package
Stdhm
Hi - we bought the roaming package to be able to use our data on holiday but we are getting the message “could not activate mobile data network - turn on mobile data or use WiFi’ but we have out mobile data turned on and on automatic selection of mobile network turned on - my Vodafone work phone connected to a local network immediately - any ideas how to get our EE phones to connect?
