Can not use my phone abroad - Unlimited Data and Calls
JideO
Am in Australia and cannot use my phone. I have unlimited data and calls, monthly contract.  When I send ROAM to 150. It says my phone is ready to be used abroad but  I cannot use it for calls or data. Please help. I cannot even make any calls either.
20 REPLIES 20
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. Did you receive a welcome text message on first arriving abroad? That would be a good indication of roaming being active and thus allowing a local network connection.
Yes I did
And have chatted to EE.
It connects I get service a a few seconds then it drops off.
I tried another phone and all providers show up as forbidden
Am in Australia
Can't send text
When I attempt to .ake calls I get an error message - NOT REGISTERED ON NETWORK
What are you answering "Yes I did" to?
Your symptoms are consistent with roaming not being active, and consequently no local network coverage.
I have unlimited calls and data.
@JideO   Have you purchased a roaming add on ?   I don’t mean the text to 150 to enable roaming.      The add on allows you to use your call/text/data allowance.
Have you tried restore device since you got there ?
Now full history of this OP's convo.
Looks like this poster has started numerous threads, rather than keeping all the replies in the same place. @JideO  Please use the "reply" option in this post to keep any replies together, instead of starting a new post.
It's unclear whether you have texted ROAMING to 150 before leaving the UK, to enable roaming. It's unclear whether you received a welcome text message on arrival - which would be good evidence of roaming.
All the symptoms described thus far, are good evidence of roaming not being active. This prevents a connection to foreign networks, with predictable consequences for your ability to use network-based functions such as calls & texts.
Your only recourse now will be to contact EE CS via another means, and request roaming is activated - your billing add-ons are irrelevant for this. If you can get a WiFi connection, try using Skype to call +44 800 0798586
I did text roaming and have been in via chat with EE
