Calls
Tamdc1
Hi I have traveled to Menorca Spain from the uk and I can’t make any calls or tex messages I can’t also get customer service says not allowed to call this number
@Tamdc1 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
