13-02-2023 08:00 PM
I am in St Vincent. My data roaming is on. EE have confirmed I have worldwide roaming. I am connected to Digicel the local Caribbean network. I can call UK numbers. When I call a local (St Vincent) number I get "call ended" with no ringtone. Note that the local number, in the format I dialled is operational - my wife can contact it on her phone (also on Digicel). Using 150 I get "cannot connect the number dialed". Cannot find a way to talk to a human at EE.
Help please all guidance greatfully recieved. Thanks
15-02-2023 04:54 PM
Hi @BazzaS,
Did the call end after you received the PIN? The advisor would normally ask you to give the PIN verbally to confirm your identity.
15-02-2023 05:01 PM
15-02-2023 05:27 PM
Hi @BazzaS,
It sounds like your call was disconnected in error. Please get back in touch on 150 so the team can verify you and access your account.
15-02-2023 05:33 PM
The symptoms described here, sound like "call abroad & premium rate" hasn't been enabled. As already advised - calling CS is the solution.
