Calls from abroad going straight to voice mail
Neil-01
Can someone please tell me how to stop my phone going to voice mail from calls abroad? I want to be able to pick up my phone calls.
7 REPLIES 7
Jon_K
Former EE Employee
Hi @Neil-01.
Welcome to the community.
Is your phone ringing at all or just going straight to voicemail?
Do you want to fully remove voicemail?
Jon
  1. Hi Jon, thank you for your message.
It is NOT ringing at all goes straight to voice mail, when my mum or sister try calling me from Australia.
I don't ever use voice mail so yes I want to remove voice mail. Is this possible and will calls will ring through so I can hear it a pick it up?
Many thanks
Neil
Neil-01
My problem had not been solved so why is it saying it has been solved?????
Jon_K
Former EE Employee
Hi @Neil-01.
Are you able to receive calls form UK numbers?
Can you make calls to the two numbers in Australia?
Jon
Yes i am receiving call calls from UK numbers but not from overseas.
Yes I can make calls to the two numbers in Australia.
They can not get through to me. So please help me how to solve this problem?
Jon_K
Former EE Employee
Thanks @Neil-01.
Do you know if these numbers are able to call other UK numbers?
Since you're able to make and receive calls in the UK, and also to the two numbers in Australia, it's difficult to pinpoint where the problem might lie.
Jon
To turn off VM text VM OFF to 150.
