Calls and texts not working
Ali_M_87
Hi. I’m in France. Have the Roaming add on, can use data, receive calls and texts but can’t call out or send messages. Can anyone help?!
10 REPLIES 10
Any billing add-on is immaterial if you're on pay-monthly, but if you can use mobile data and receive calls, that's the proof that roaming is active.
What happens when you try making a call? And which networks is this happening on?
Often changing networks manually or by toggling flight mode, can assist with network problems abroad.
Northerner
Hi @Ali_M_87
Are you adding +44 to your numbers?
I have ‘dial assist’ activated and so yes I do.
Thanks.
Sent from my iPhone
Hi. There’s a recorded messages saying that these calls aren’t included in my package, messages just done get delivered.
Thanks.
Sent from my iPhone
Something about this is odd - your package is of no interest or concern to foreign networks.
You've mentioned a billing add-on, which suggests you are on pay-monthly. Are you? If so - any non-inclusive charges are simply added to your bill, unless you have a spend-cap active. Do you?
If on PAYG, then your credit allowance directly dictates your ability to make calls and send texts.
The other option is a temporary issue with the local network you're connected to - resolved by manually selecting an alternative.
Do you have a data, not phone, SIM? What device is it in?
No, my sim is for all things. Never have problems in the UK, just since being away, even though I’ve bought the pass. It’s an iPhone.
Sent from my iPhone
Leanne_T
Hi @Ali_M_87
Have you tried connecting to a different network in your iPhone Settings > Mobile Data > Network Selection, turn off automatic and manually search for other networks.
Can you try connecting and making a call, does this work for you?
Yep. I have gone through all the networks and I either get a recorded message or it just beeps and cuts off.
Thanks.
Sent from my iPhone
