on 12-06-2022 07:10 AM
I am travelling with work colleagues to Indonesia and will need to make regular calls to one another. I will also need to call the UK. I have a sim only deal. What will be the cheapest add on to use?
Solved! Go to Solution.
on 12-06-2022 08:06 AM
Welcome to the community.
Have you had a look at our online roaming tool? That will show you available add-ons so that you can choose one that best suits you.
