Call Forwarding
LCKong
I’m outside UK now.
I would like to forward all incoming calls to another UK number.
I tried to fail **21*020xxxxxxxxxxx #, but it failed.
Can I do it by login my account via notebook without using the phone?
Are you on PAYG or pay-monthly? PAYG only supports call forwarding to voicemail.
Assuming that isn't the case, you should be able to set diverts using your phone's call forwarding menu - the location differs between iOS & Android.
Diverts can only be set from a phone with the SIM inside.
