Bt hotspot
Profile closed
Not applicable
I have got Btbroadband 100 with halo.
which offers free Bt Wi-Fi hotspots.
Mobile phone is with EE.
So is it possible to use a Bt hotspot.
@Profile closed  are you already connected to Wi-Fi when you try it?
Are you able to see a BT Wi-Fi Hotspot if you go to Settings - Wi-Fi on your iPhone?
6 REPLIES 6
Mustrum
@Profile closed   you should have a username and password for your BT Wi-Fi so would just need to log into one when you were away from home.
Or did you mean something else?
Profile closed
Not applicable
I have got the Bt wi-fi app on my iphone
When I click on that it just says not connected
. when I was with Bt mobile it would come
up with a list of hot spots.
Profile closed
Not applicable
Yes just tried it, i know what to do now
thanks for your reply’s
Glad its sorted, and thanks for letting us know.
There used to be something called EE WIFI Coverage Boost which is referred to in Using WiFi on the London Underground :
In fact, you’ll also seamlessly connect to 150,000 hotspots across the UK to extend your coverage where you need it most.
which in fact would be BT WiFi, but it seems to gone AWOL & the link in above article does not take you to it.
