Australia with Roam Further - also unlimited data add on?
LFB1
I just want to check that I’m understanding the T&Cs correctly.
I’m going to Australia for 4 weeks. I’ve added Roam Further, but I could do with more data.
Am I right that I can’t use the unlimited data add on in Australia?
@LFB1  That’s correct you can only use up to 50GB per month when roaming
Thanks.
I only usually have 16GB. If I buy an add on (the unlimited one is most cost effective) does that mean I can use up to 50GB in Aus?
I’d read the T&Cs to mean that the add ons could only be used in Europe.
James_B
EE Community Manager
Hi @LFB1,
Yes, you can use your UK data allowances (up to 50GB) in Australia when using the Roam Further/Roam Abroad pass.
