Apps Not Loading When Wifi Not Available
Guvnor_1947
I recently transferred accounts for two Iphones from O2 to EE. On one phone apps load when out of the house and no Wifi available. On the other phone, apps load OK when able to access Wifi, but will not load when out of the house and Wifi is not available. I have cross checked the settings on the phones and they are the same. I have tried disabling VPNs, ensuring data roaming is on and have done a network reset but to no avail.  Can anyone help in resolving this problem?
1 ACCEPTED SOLUTION
Rach_H
I'd recommend reaching out to our Techincal experts @Guvnor_1947, and they will be able to take a look into why you're not able to get online.
Rach
15 REPLIES 15
Why? Are you abroad? If so, your nos. may not port while there.
Not overseas. In the UK.
@Guvnor_1947  What apps ?  If it’s any social media apps then it’s probably content lock that’s blocking this.  You need to call customer support with a credit card pay a refundable token to have content lock removed or you can go to a store with date photo ID to request content lock to be remove.
Guvnor_1947
Chris. Main ones I have tried to use recently are Google Maps, MacDonalds, ICC and Utilita Apps. None of them will load properly. Yet the same apps on my wife's phone all load quite happily when not on Wifi.
Rach_H
Hi @Guvnor_1947,
Welcome to the Community!
I'm sorry to hear about the trouble you're having. Are you able to browse the internet when you're away from WiFi, and can you make calls?
Rach
Guvnor_1947
HI Rach,
I gave it a try. I went to the end of my garden. Disabled Wifi. Tried three different apps. The front page loaded in all three but then nothing else. Called my wife on home phone and it worked fine.
Peter
Is your mobile data enabled? Have you restarted your phone?
EE Pro TV box, Full Fibre 900
For EE contact details see
https://ee.co.uk/help/contact-ee
I kept my fingers crossed as I hadn't restarted my phone for ages. Restarted but no difference. Yes data roaming enabled. Tried to load a route on Google Maps. Got the message "Cannot show revised route as cannot connect to the server".
Rach_H
Rach
