on 24-03-2024 01:42 PM
Hi I am in Colombia and forgot to do the 150 to ROAMING before I left .
Please help as I use to need to use my phone for calls ,data, etc
The travel pass has been activated on my account.
on 24-03-2024 03:35 PM
Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
You need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 24-03-2024 05:58 PM
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
