All calls to my Galaxy A52s going to voicemail. Help please !!
Vykkie
Northerner
Hi @Vykkie
Text VM OFF to 150.
Also make sure you haven't set all calls to voicemail under your call settings.
Is your phone showing signal indicators, and are you able to make outgoing calls OK?
Check you've not inadvertently set a DND (Do not disturb) mode.
I can confirm that I can make outgoing calls.
Where do I look to see if I've accidentally set a DND, please.
Thanks for all the help !
James_B
EE Community Manager
Hi @Vykkie,
You should see the do not disturb button in the quick settings panel if you swipe down from the top of your phone.
Hope this helps.
