Daughter went to morocco today without enabling roaming - how can she enable
Roger34
My daughter flew to morocco this morning and neglected to switch on roaming ahead of time.  She has not got her memorable info to log in to the ee site online.  How can she contact you yo get roaming switched on?
@Roger34 : Is she on contract or PAYG? Did she use that SIM for making calls or texts in UK before she left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise login to her MyEE account online & go to Menu > Account Settings > Parental and Data Controls > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If not ticked, can you activate these settings?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of her online MyEE, she will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as she's used the SIM in the UK previously. she won't see any of those settings & don't need to change anything. If outside EU, does she have enough credit for making calls & texts from abroad?
