Accessing EE voicemail from Australia.
Skytime
How do I access my EE voicemail from Australia? If you’re in the UK, you just dial 22201, but that won’t work from here. I know you have to start with the country code (+44), but there needs to be more numbers after this & before the 22201 to access voicemail.
Christopher_G
Hi @Skytime
Welcome to the community.
Try this number: +44 7953 222 222. You would have had to have set up a PIN number for your voicemail before travelling.
