30mins anywhere
Carl2010
Needed to make an emergency call from Turkey purchased the 30min anywhere package to do this. Turkey is on the list of countries but I could not make any calls went through settings tried changing them still nothing. How do you get your money back
6 REPLIES 6
Katie_J
Hi @Carl2010.
Welcome to the community.
Although you have purchased an add-on you will need to have roaming activated on your EE account.
Did you text ROAMING to 150 before travelling abroad?
Katie
Never new I had to do that only needed to make 1 emergency call. Had to borrow someones phone in the end. So you have to text to set up 30mins of calls not just a simple add-on
Katie_J
To use your phone outside the UK you will need to have roaming active @Carl2010.
Our customer care team can activate this for you if you have already left the UK.
Katie
Am in Turkey already, if I did not activate roaming am I still going to get charge for a service I could not use, have cancelled the package already without using it
Thanks for your fast reply
Katie_J
I'd recommend speaking with our customer care team as the charge will be applied to your account @Carl2010.
The team can be contacted via Live Chat that is in the EE app under Help.
Katie
