signal very poor new ferry
Stringy66
just silly now always had bad coverige have to go outside to recive calls and make them only messinger works never fix it i think you should supply outside antennes if they work looking at that they are very expensive we pay enough so no go there contract up next year looking elsewere
@Stringy66  Try using WiFi calling this is exactly why it’s there,  No network will guarantee signal indoors as buildings can block signals.
Ali_A
Hi @Stringy66
Welcome to the EE Community
Just as @Chris_B has mentioned, WIFI calling is a benefit from EE included in your service plan.
You can find out more about it at WIFI-Calling
Once activated in your device, you can leave it switched on permanently- your phone will automatically swap between the mobile and WIFI connections.
Ali
Stringy66
Ok all wifi calling is on no signal in house have to go outside to speak always breaks up even then not perfect so not all wifi calling works
WiFi-calling is fundamentally a very stable & reliable service, but many users think otherwise when one of two factors are considered.
1: It's only as good as the wireless connection it's being used over. If this is weak or poor, so can the resultant calls.
2: The service is designed to only kick-in when mobile coverage is deemed (by the phone) to be unusable. If your phone is using "mobile-preferred", it may not be using the service.
Some recent Android phones allow you to set "WiFi-preferred", otherwise try enabling flight mode (to force zero coverage), then enable WiFi-manually. Now try using WiFi-calling.
