mobile signal
carlos788
Iv had no mobile signal all day, any contact to ee is done via  a txt which i cant receive. I cannot stand this network!
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker  in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
carlos788
it is the worse customer service process iv ever known. Create a live chat you plebs instead of sending people to pointless FAQ documents!
