11-01-2023 12:23 PM
My phone is not connecting to the network, I have restarted it several times but still no luck. not sure what else i can do
11-01-2023 12:42 PM
Do you know anyone else locally who uses EE, who is also having problems? There may be an issue in your area - use "check status" on https://coverage.ee.co.uk/coverage/ee in the first instance.
11-01-2023 01:04 PM
coverage is fine in the area, I have drove from one side of Birmingham to another and i still have no network
11-01-2023 01:28 PM
Are you reporting an apparent lack of coverage in locations there should be?
Or problems making calls when coverage is displayed?
11-01-2023 02:11 PM
My phone wont connect to the network at all. i have had the same phone and same sim for over two years but all of a sudden today i cant connect. my phone is important for me to complete my daily work.
Its not about coverage, as i stated in my initial post my phone will not connect to the netwoprk at all
11-01-2023 02:15 PM
Hi @Danrobs,
Are you using a pay as you go or pay monthly plan?
11-01-2023 02:28 PM
monthly plan
11-01-2023 02:28 PM
monthly plan
11-01-2023 02:33 PM
Hi @Danrobs,
Do you have any outstanding bills?
Has your phone showed any notifications to indicate it doesn't recognise your SIM?
11-01-2023 02:45 PM
no to either of those, it just says emergency calls only. no network bars. when i go to the sim menu it recognises it
